rui-ferreira avatar image
rui-ferreira asked
Phoenix Inverter 48/5000/230 parallel config using VictronConnect
This post follows a previous one a few days ago, where I questioned the possibility of using DIP switches to parallel a second compatible inverter with the existing one which runs a FW508, and I´ve been advised to forget that and, instead, to use Victron SW, namely VictronConnect application.
But the use of this app is protected by a code, code which seems to be available only from Victron certified distributors and/or installers.
As I've done for the first and actual Phoenix Inverter, I intend to buy the second device also from an Internet supplier, and I want to make the parallel installation by myself (regardless the "complexity" of it), so my question is:.
QUESTION: as an end user, how do I get the password/code to run the VictronConnect app for parallel configuration of two Phoenix Inverters 48/5k/230 by myself?
Note: the Internet supplier for first inverter (serial nr.HQ2038****), questioned twice on this, didn't answer.
Thanks for your support, community or Victron.
Phoenix Inverter
snoobler avatar image
snoobler answered ·
Recommend stronger Google skills.
https://shop.pkys.com/victronconnect-upgrade.html
rui-ferreira answered ·
To snoobler,
Thanks for the link, your Google skill is remarkable.
But, assuming "zzz" is serious, I wonder why such a "secret code" is spread on the Internet, while Vitron keeps saying it is reserved to Vitron's certified distributors and/or installlers.
Rare thing, isn't it?
Anyway, thanks for your help.
snoobler avatar image snoobler commented ·
I personally think it's simply a test to see if those tackling this exercise have done basic research on the topic and bothered to read the manual:
https://www.victronenergy.com/media/pg/VictronConnect_configuration_guide_for_VE.Bus_products/en/index-en.html
