What charge curve should i use or is better?
I have a MultiPlus12/300/50 with 3x 12v/200ah Vicrton Smart batterys.
What charge curve is best to use?
Fixed or adaptive with BatterySafe mode?
All the answers are in the battery manual:
https://www.victronenergy.com/media/pg/Lithium_Battery_Smart/en/operation.html#UUID-da256977-e24c-e908-0be5-fb0559ec738e
Really not...
It says "A typical charging profile ... looks like the graph below"
My qusetion was ... Fixed or adaptive with BatterySafe mode... to use or which is better?
With lithium batteries, turn on the lithium setting. About all you need to do is check absorption and float voltages are correct. Leave in fixed mode. Adaptive is available, but meant for lead based chemistry afik. There's no battery life option for lithium.
112 People are following this question.
How can Multiplus 1 be used to increase charge power in ESS system with Multiplus 2 and GX
>10kVA and dedicated production meter
Camper Van Schematic - please critique
Are my MultiPlus II VE Config charger settings correct for 4 x Omnipower 200Ah batteries?
firmware compatibility three phase system MultiGrid-II and MultiPlus-II
