mctree avatar image
mctree asked
Voltage output limit?
I have a Victron 12/24 15A Orion Smart isolted DC DC converter that I am trying to set up to power my Ecoflow Delta 2 from my Land Cruiser alternator. When I first turn it on, it will increase the 13.7V output coming from my land cruiser to 28V as I have set it. This puts around 370watts into the Ecoflow. In testing I have run it for an hour at the output drops a bit due to heat, but not much.
If I turn off the land cruiser and the Orion senses this, it will shut down as it should.
The problem is that when I turn the Land Cruiser back on, the Orion will not put out more than 20V or 280 watts into the Ecoflow.
Is there a setting that I need to use to get the Orion to return to the 28V it initially output?
orion dc-dc
Alexandra avatar image
Alexandra answered ·
@MCTree
Maybe check your rebulk offset?
mctree avatar image mctree commented ·
Hmmm. In what way?
I’m sitting here testing and have tired moving it up to 4V and down to .02V. Not seeing a difference.
After I stop charging, the Orion limits itself to 20V output until I shut the Orion down completely and wait a couple of minutes for it to lose all internal power.
Then I can get 28V out of it again.
