UPDATE 2024-04-24 - v3.31 has now been released - https://professional.victronenergy.com/news/detail/242/
Good day!
Per just now, we released beta version v3.31~3 to be tested.
This version is mostly fixes and stability improvements, and assuming that its a clean result then we're keen to release this already early next week. Directly after that we'll continue the testing of the v3.40-beta series that include gui-v2.
Feedback appreciated! Please keep it clean: no feature requests, no questions about why gui-v2 is not available. All I'm interested in now is that all available functionality is stable and working as it should; as well as that the mentioned fixes are effective.
Instructions: Venus OS beta testing & how to join/install
In case you don't know what this message is about, please start with reading this link, which explains the Venus OS beta program. Venus OS is the software running on all our GX devices, such as the Cerbo GX.
Instructions: How to post an issue?
By posting an answer below. Do please keep all findings organised: one answer issue per issue. So first check the existing threads if your issue has already been seen. And if it does, add a comment saying "me too". And preferably some more details. And in case its not listed yet, add a new Answer.
Note that Answers and Comments are two different things on this portal.
Lastly, before posting issues, preferably first revert to the latest official release, to double check if the issue you're seeing was present there as well. Regressions require a different treatment than other issues and bugs.
And include information about the results/differences in behaviour in your report.
Instructions: Node-RED, Kevinās GuiMods or other add-ons?
In case you are running Node-RED or SignalK, then please at least say so in your bug report.
GuiMods and other 3rd party add-ons: donāt report your gui issues here. Do it elsewhere instead.
Changes made by us can cause a compatibility issue with the GuiMods; and these betas report pages are for official firmware only.
Change log
v3.31~4
- Fix EVCS firmware updates over VRM failing on fast network connections.
v3.30 -> v3.31~3
- fix gui getting stuck sometimes, showing a small green square locally on the GX Touch and Ekrano GX as well as causing Remote Console to not work. This issue was introduced in v3.30.
- gui: fix alarm icon showing while there is no alarm, issue was introduced in v3.30
- gui: remove DESS Minimum SOC menu entry, since that is now configurable on the VRM portal rather than in the GX menu structure.
- Dynamic ESS: fix bug where PV from grid-inverter was fed back into the grid rather than used to charge the battery, in certain conditions.
- VM-3P75CT Energy Meter: fix power readings not properly available when using multiple of these energy meters on the same VE.Can network.
- FlashMQ, an internal tool : update from v1.9.1 to v1.11.0 as well as allow empty usernames. Allowing empty user names fixes certain MQTT clients not being able to login as well as other tools that used to work up to Venus OS v3.20 but didn't since we switched to FlashMQ. For the complete FlashMQ change log, see https://github.com/halfgaar/FlashMQ/tags. And for more details on this issue see https://github.com/victronenergy/venus/issues/1257.
- Add mosquitto_pub and mosquitto_sub clients to the standard toolset on Venus OS.
- Venus OS Large, signalk-server:
- Update signalk-server from v2.5.0 to v2.7.1. Change log: https://github.com/SignalK/signalk-server/releases.
- Update signalk-venus-plugin from v1.34.0 to to version 1.34.1, which fixes a rare crash. Change log: https://github.com/sbender9/signalk-venus-plugin/releases/tag/v1.34.1.
