seppolalypse avatar image
seppolalypse asked
Limiting solar panel current at SmartSolar MPPT xxx/xx via Bluetooth configuration
Hi All!
I have 3 Questions:
1.) Is it possible to limit the current of the solar panels at a SmartSolar MPPT xxx/xx via Bluetooth configuration? For excample, I have 3x2 420W solar panels (in total ~2500W peak) which shall be connected to 1 SmartSolar MPPT in order to load a 10kwh 48V battery. Can I limit the current to e.g. 20A to conserve the battery capacity?
2.) What if the battery is full; I guess the MPPT will stop loading by measuring a different voltage at battery side?
3.) Is it possible to detect the capacity level (0-100%) of a LiFePo battery by the SmartSolar MPPT?
Thank you all in advance for your time and effort!
BR,
Sebastian
MPPT SmartSolarBluetoothcurrent limit48v battery150/35
