I have Phoenix Inverter 12/375 watt inverter. With no load connected to the output, the inverter consumes 23 watts from the 12V battery. Is 23 watts excessive power consumption for an inverter that has no load connected?
Yes, that is excessive. The data sheet states 5,6 W for a VE.Direct 12/375. What is the reading when you enable Eco-Mode? Do you have a Smart Shunt so you can measure the real draw?
I bought the Phoenix exactly for that reason: my 24/800 has an idle consumption of 8 W, in ECO mode it is 0 W.
Sounds as if your device is defective, but I am not an expert.
46 People are following this question.
