beeeeep-beeeeep avatar image
beeeeep-beeeeep asked
phoenix 12/500 lower votage battery bug?
Hi everybody!
I've got a weird behavior on my phoenix inverter.
I don't know exactly when and why it occurs, but three days ago I charge a laptop (90 W) and the red faulty led light up (after two hours, full sun). Ok, I switch it off. Two days later, I restart it, plugged in my laptop again and the phoenix was still faulty. I plugged in the Ve.Direct and I saw the lower voltage battery notification but the battery was in charge (mppt 100/20) at 13.60 (kind of fully charge) but impossible to make it work. I finally had to change the charge detect setting to 14V to 13V to make it work. But I don't know what exactly this setting is doing and It was working for 2 years before that with the previous setting. (the other settings Low battery shut down are 11V and alarm 11,1V).
I saw on the Mppt that the batteries went under 9V the 5 last days for no reasons (maybe dead batteries, still monitoring it right now). But it should not impact the inverter behaviour in the day (13.6V) as I understand it.
Also I had the Inverting remote on-off cable (ASS030550120) plugged. i tried without and with the jumper cable and nothing changed.
Anybody has any ideas of what could be wrong/has changed ?
Thanks for your answers
Phoenix Inverter
Sounds as if your batteries have died. Recording 9V is usually end of life. Voltage will come up when charging, but as soon as there's a load, the voltage drops right off.
beeeeep-beeeeep avatar image beeeeep-beeeeep kevgermany ♦♦ commented ·
I know it sound bad for the batteries but after monitoring all night, they didn't fall under 12V. Today, I charged my computer completely (only the batteries and the inverter were connected) without any problem. The charge hold above 12.2V during an hour and a half.
Any other ideas ? Could it be a bad contact ? The Mppt would have prevent a charge put the batteries under 11V...
kevgermany avatar image kevgermany ♦♦ beeeeep-beeeeep commented ·
Could be bad contact, internal problem in cables. You're going to have to trace it.
