I have my Orion Mounted on a vertical wall with the fan pointing down. Plenty of open air flow around the unit. Is this described orientation acceptable?
I contacted Victron Support and received the following response to my question. Hopefully this will help someone else with their project. “Victron Energy has given us your support request. Orientation does not matter for the mounting of these devices, and it should be fine as is.”
Looks as if there's no path for air to get in from the bottom. Suggest you move it up. And if the box will be closed, provide ventilation holes.
Victron DC to DC Converters Product Range
__________
42 People are following this question.
