jodel avatar image
jodel asked
MPPT 75/10 not charging
Hi, I have a 100 watt flex solar panel on my boat connected to a MPPT 75/10 . The system is less than a year old and was working fine. Now it is no longer charging. I am not sure if it is the panel or the controller. The open circuit voltage on the panel is 18.6. When I connect the panel to the controller it's voltage drops to 16.5. The battery voltage is 13.5. there is a mains charger connected also, but this has never effect things before.
VE direct shows voltage but no amps from the solar panel and battery state as off.
Any suggestions as to how I can fault find the issue?
Jodel
battery chargingSolar PanelMK3
PV voltage has to be 5V higher than battery voltage to start charging. After that it has to be 2V higher.
4 comments
jodel avatar image jodel commented ·
Thanks. I'll switch off mains charger to get battery voltage to drop.
Just wondering why it has to be 5 volts higher to start. Can this value be changed?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ jodel commented ·
No, it can't be changed. It's the way this MPPT works.
jodel avatar image jodel Matthias Lange - DE ♦ commented ·
I switched off my mains charger this morning and when the differential reached 5 volts the solar kicked in.
I have a 12 volt 45watt compressor driven fridge running full time so it should be drawing approx 4 amps.
It midday here in full sunshine and the max the panel produced all morning was P max. 9 W. It has now stopped charging again. I thought it might go into float mode
The battery voltage is 12.77.
I would have expected the panel to be producing the 4 amps that the fridge is consuming.
Is my panel suspect?
