Matt drummond bell avatar image
Matt drummond bell asked
remote help dw serial
pi 3+ running venus, 3x multi plus s , pulquero battery aggregator, hyandai 120ah 3.7v cells
6x daly 12s 48v bms. victron mppt 150/100, fronius grid tied on pv assistant. so 6x usb serial adapters to powered usb hub everything running through pi. i have a gx color control but it keeps crashing when plug usb bus in.
dbs set to 4.00 as per dbs setup, min 3.6, i think float 3.8 as a guess, daly bms. daly bms-1
why over voltage ?? and high volatge alarms ?
it wont let me turn dvcc on as stops charge current. i have to disable, and set as battery aggregator as controlling bms. it was working through dvcc before! volatge and current control. now it just disables all charge! can anyone offer me a remote fix?
this is runiing a campsite and i need it to be stable! or should we just return to agm?
hhhhhhhheeeellllppppp!!!
matt
BMS
Matt drummond bell avatar image Matt drummond bell commented ·
oh generator 20kva.
stand alone system.
inverters set to 49.00v absorb
i think 24amp each input through ac1
if any help i can give exact figures
