Cerbo GX running v3.30 firmware does not show SmartShunt HQ2249 running v4.14 firmware. The SmartShunt appears on VictronConnect.
Is this a fatal hardware issue?
Hello slazrove, did you solve the issue? I have the same problem.
The victron VE.direct cables should be 1:1 wired are they not ?
thanks
SOLVED ! Swap the two middle RX/TX wires
98 People are following this question.
