bocas-uflex avatar image
bocas-uflex asked
Multiple Smartshunts with Cerbo GX
Hello, I'm currently setting up a boat as follow:
  1. smartshunt house battery bank
  2. smartshunt for bow thruster & engine 1 battery tension
  3. one smartshunt for AC battery bank & engine 2 battery tension
cerbo GX & GX touch 50 for monitoring the full system.
Is there any special configuration I have to do to show all ?
Thanks Guys!
cerbo gxSmartShunt
Paul B avatar image
Paul B answered ·
As far as I know you can only select/show one smartshunt / Monitor at a time on the cerbo and this is done in the setting selection area,
safiery avatar image
safiery answered ·
You can see many smart shunts. Do this: login with Victron connect. Update the smart shunt to latest firmware. Then select gear wheel for each shunt and select “misc”. Then select the type of power/energy measurement. There is a long list of current source and load devices showing. Then rename and save. They will all appear on the device list but more importantly on the dashboard of the VRM
Paul B avatar image Paul B commented ·
But not on the cerbo
duane avatar image
duane answered ·
You can show all 3 by using a raspberry PI and Grafana
With a custom dash
For sure and you can do this on a cerbo as well, but not in its standard form, Kevins mods are getting close and he may even add this as one of his screen one day
duane avatar image
duane answered ·
2 smart shunts
3 solar controllers
1 inverter
