Hi there,
Just tried to save a settings file to a windows network location (SMB/ samba linux server) and it's not getting stored. Tried the same to a local HDD and it did get stored.
Hi there,
I think you might find this is an operating system limitation. I can and do save settings from Victron Connect to my NAS at home directly from my android phone.
I'm sorry for the misunderstanding but I run victronconnect on Windows 11.
So in windows 11 running victron 6.03 (and earlier betas too) it is not possible to store on a SMB network drive.
I will look into the server side of things to see if i can find incompatibilities.
Is the smb share mapped to a drive (via map network drive) or is it accessed via its smb address \\servername\share\... (via add network location in windows)?
While trying to reproduce the issue, we found that using a mapped share does work but using the smb address doesn't work. We will look into this issue whether this can be fixed / improved.
Kind regards,
69 People are following this question.
