delt127 avatar image
delt127 asked
Battery Reads 24.65V, but Battery Monitor states only 65% ... why?
BMV 712, CCGX, Multiplus, and my personal multimeter all have the Tesla battery at 24.65V. Yet the BMV 712, CCGX, and Multiplus all report the battery at 65-68%. Why?
Note: Happens both in solar charging and in grid charging. I have the Multiplus Absorption=24.6V, Float=24.5V, Charge Current=70A, Repeated Absorption Time=0.25hr, Repeated Absorption Interval=45 days, Max Absorption Time=1hr.
batterySOCvoltagebattery capacity
Mark avatar image
Mark answered ·
For the BMV to function effectively it needs to be setup to;
1- Monitor and report the SOC% as accurately as possible (in relation to the true SOC%)
2- Synchronize regularly to reset to a known/true 100% SOC baseline
If you are confident that your battery is really fully charged, but the BMV is indicating ~65% SOC then I would work on tuning the sync parameters - 'charged voltage', 'tail current' and 'detection time'.
I would also conduct another full charge cycle while carefully monitoring the charge current at the end of the absorption phase just before switching to float phase and comparing this to the current BMV 'tail current' setting. If it is not dropping below the trigger threshold then it won't synchronize.
The issue/complication that I see with your current charging parameters is that absorption and float voltage are almost identical, so this may be difficult to work with for BMV synchronization.
For solar applications you typically set the 'charged voltage' to a little under the charger 'absorption voltage' and the 'tail current' to ~2% - that way when the battery voltage is over the 'charged voltage' AND the charge current drops below the 'tail current' and this is maintained for the 'detection time' it will automatically synchronize to 100% SOC.
Further info & reading;
BMV Manual;
https://www.victronenergy.com/upload/documents/Manual-BMV-700-700H-702-712-EN-NL-FR-DE-ES-SE-PT-IT.pdf
BMV Setup Videos;
How to optimise the BMV-700 series sync parameters
https://www.youtube.com/watch?v=4ReljfO3k6M
Sync settings for Lithium batteries
https://www.youtube.com/watch?v=yMJ_vzB2avE
Introduction to the BMV 712-smart
https://www.youtube.com/watch?v=2vA-EjSSBVA
delt127 answered ·
Just accomplished the above, works great. Thanks @Mark!
Mark avatar image Mark ♦♦ commented ·
No problem, I'm glad to hear that. Thanks for reporting back.
