AC current input limit does not allow me to go below 9.4A with a MultiPlus-II 2x 120V (3000) and cerbo GX. I used to be able adjust it all the way down to zero but I'm not sure what happened. ESS and powerassist is enabled. Thank you!
With ESS assistant installed you should not have power assist enabled, as ESS handles this automatically. Disable power assist and you should be able to lower the ac input limit.
Hi @lukealm
There's a minimum you can set with Power Assist enabled, so I looked it up..
If your model is 2780, then it's 9.5A. Not 9.4A but close. The only way to get down to zero is to delete Power Assist, but I doubt you'd want to do that. This isn't new, but there's several places you can set this, and might actually show zero when you type it, but it won't stick.
109 People are following this question.
