Mike Gillming avatar image
Mike Gillming asked
smallbms ATC output
Hi, looks like need to add a 'Small bms' to safely charge my two new 100ah Victron LFP batteries. Can I connect the bms output, ATC, to the 'remote' of both my victron MPPT 100/30 solar controller, AND my Victron Orion 24/12 DC/DC controller (24dc alternator)?....cheers
BMS
Mike Gillming avatar image Mike Gillming commented ·
Um, did a bit more research, question still stands but I will need to get a 'V.E.direct inverting cable' for the MPPT controller
klim8skeptic avatar image klim8skeptic ♦ Mike Gillming commented ·
@Mike Gillming Depending on the type of Orion (isolated/non isolated) would require a specific "cable" for the Orion.
Got an inverter/inverter/charger?
Mike Gillming avatar image Mike Gillming klim8skeptic ♦ commented ·
Thanks mate, Upon further reading, yes the Orion is a 'Tr', so according to the Appendix, "all Tr's" will can be controlled by a single conductor to the remote. And my MPPT requires a special cable. I suppose the real query is controlling two different devices. I've seen were three MPPT's were all linked, so I'll give it a try...thanks again for responding...cheers
