jakecloss avatar image
jakecloss asked
compatibility of the following products.
I would just like to check the compatibility of the following products.
Victron EasySolar 5kva. https://www.victronenergy.com/upload/documents/Datasheet-EasySolar-with-Color-Control-EN.pdf
BYD Battery-box pro LV http://www.windandsun.co.uk/media/1061521/byd-battery-box-pro-lv-datasheet.pdf
3X BYD B-Plus LV Battery modules 2.56 KWh usable http://www.windandsun.co.uk/media/1061521/byd-battery-box-pro-lv-datasheet.pdf
KIPOR 5kva Diesel Generator 6700TA . https://www.macfarlanegenerators.com.au/download?fid=1322
Thanks.
charge controller compatibility
byd-service avatar image
byd-service answered ·
All the BYD 48v models are compatible with systems using CCGX or Venus.
JohnC avatar image
JohnC answered ·
Great you're asking, not grasping,, :)
Re the BYD: https://www.victronenergy.com/live/battery_compatibility:byd_b-box
There may be issues with sizing the pack etc, and our local BYD man will maybe curse me for summoning him, but I'll wear it..
@BYD_service He will come..
Your Kipor should be ok, You can control it's output level from within the CCGX, so can be set to whatever you decide is a comfortable output. It's possible the Multi will baulk at it's power quality, but that's fixable. Ask if it happens.
jakecloss answered ·
So just to be clear all information about BYD battery's on victrons Battery Compatibility page is correct?
Also does easysolar 5kva 48 5000 use CCGX or Venus system.
thanks again jake
JohnC avatar image JohnC ♦ commented ·
It should be current, else our eft/byd man would have had it fixed. (Note his response time was just 8 minutes yesterday, that's good service). I'd be happy buying byd, and may well do when my Pb's croak. Just make sure you size them large enough to cover the rated demand of the Multi 5000 inside your Easy.
The CCGX and VenusGX both use the Venus OS firmware, and for you will be functionally identical. Some hardware differences that shouldn't impact you. The CCGX is the more expensive unit because of the screen, which you'll find handy with your 'remote' installation.
Ok sorry. I think I was reading the chart incorrectly.
So with the byd pro 2.5 I will need 1 battery module for self consumption and 3 battery modules to meet single phase minimum requirements totalling 4 battery modules
