I have a Solis pocket van and I'm trying to add a shunt for my lifpo4 batteries I updated from AGM. When I look at the wiring I'm confusd on where to put the shunt.
Hi @k5tao22
To measure both batteries together you'll need to join both 2 negative terminal wires to the 'Battery' terminal of the shunt. Then the 'Load' terminal goes to 'Van'. If 'Van' is a chassis earth return then that's ok too.
https://www.victronenergy.com/media/pg/SmartShunt/en/installation.html
You could actually remove the rhs negative wire to Van, it isn't necessary.
Can the shunt be installed on the front battery (point A) on a px, which is much easier to do?Screenshot 2024-03-21 at 10.55.20 PM.png
54 People are following this question.
