trent-w avatar image
trent-w asked
Re adjust Battery values and parameters
Hey guys
I have a Orion 12/12 30 dc dc charger and would like to Re adjust my parameters. Do I have to go through the initial procedure again such as isolate power, disconnect bridging wire adjust on APP then connect all again? Or can just adjust on the go via the app? Thanks
orion dc-dc
pwfarnell avatar image
pwfarnell answered ·
Just use the app, I alter my MPPT charger with it running. If you want to be more cautious, when going into battery settings one of the top items is "Charger enabled", disable the charger while you make the changes then re-enable it.
trent-w avatar image trent-w commented ·
Thanks so much
