Hello, I have a question about the relay of the Cerbo GX.
Can I use the relay to switch when I put in shore power? So that I can make a light which will go on when I plug shore power in?
Thanks!
Hi @goon326
I'm not sure if you can do this with VeConfigure assistants however take a look at node red.
I dont have cerbo so cant confirm but i can control my mppt relay from there.
I can also see grid status in node red. So could in theory make what you're looking for work.
90 People are following this question.
