biswa avatar image
biswa asked
How battery temperature reading of Multiplus II can be show up on VRM portal?
Hi, I am using Victron Multiplus II for almost last two years with out any issue. Also using Venus OS through raspberry pi & it helps me to monitor my system through VRM portal.
But I am unable monitor my battery temperature on VRM portal.
Multiplus II comes with a battery temperature sensor & battery temperature is showing in Venus OS as below.
Can any body help me on this?
VRMtemperaturewidget vrm
daza avatar image
daza answered ·
Go into advance and then the top right with all the settings select VE bus enable group widgets you should see battery temp there try that
kevgermany avatar image
kevgermany answered ·
1000016012.jpgIn the VRM dashboard click on show details.
Temp shows in the battery box.
JohnC avatar image JohnC ♦ commented ·
You may need to enable DVCC (STS) to share and report T as a system value.
biswa avatar image biswa JohnC ♦ commented ·
Thank you very much John for your suggestion. It's worked.
