blacksmith avatar image
blacksmith asked
can two inverters be controlled by one smart BP ?
I have a simplex 600 watt pure sine wave & and 3000 watt Exeltech pure sine wave running separate systems from a bank of Lead acid batteries. I'm converting over to Lithium LiFePO4 batteries . can I control both inverters for low voltage with one smartBP 220 or do I need to use a separate BP for each inverter?Both inverters have a remote option.
Smart Battery Sense
Justin Cook avatar image
Justin Cook answered ·
As long as the two inverters' remote trigger functionality works the same, no reason you can't use the same SBP for both. You're not running any current through the SBP, you're just using it to supply and interrupt a signal, so as long as each inverter is looking for the same sort of signal then you'd be good.
blacksmith avatar image blacksmith commented ·
Thank you.....
Smart Battery Sense Product Page
Smart Battery Sense Manual
