danielson89 avatar image
danielson89 asked
Storage Mode First Time
Hi All,
Sorry for all the questions, very new to Victron.
I’ve got the RS Multi 450/6000/100
It’s been running for about 2 weeks now, I recently added 8 more batteries to the 8 batteries already had so 16 total. I removed 4 because they were low in voltage (my fault for not checking brand new batteries). It was discovered 15 minutes after connecting I heard them sizzling away. I’ve checked all the batteries that are connected now and they are all at around 13.6 except 3 of them they are sitting on 13.5ish which is odd. Today the unit went into storage mode? It’s grid connected and I’ve run those batteries down to around 58% in the last 2 days. Any idea why storage mode was activated?
I’ve always only seen: BULK > Absorption > Float
Thanks
battery charginggridvoltage
Alexandra avatar image
Alexandra answered ·
@DanielSon89
Check your Storage voltage. It is settable with some profiles.
And storage mode may be because you had floated for a while? You are right though it is usually 24hours in float before storage used to activate. So interesting.
It is a feature of adaptive charging. I guess you know this already Storage mode is to reduce unnecessary off-gassing on lead acid batteries (float voltage is high enough to cause some off-gassing)
You older batteries may not have due to higher internal resistance leading to higher self discharge?
VictronConnect VE.Bus charging manual
