ingo21 avatar image
ingo21 asked
setup 2 Victron Phoenix Inverter 24/800 in parallel
are the Victron Phoenix Inverters 24/800 designed / able to run parallel for more VA output?
Phoenix Inverter
Alexandra avatar image
Alexandra answered ·
@Ingo21
Does it have a VE bus port? Or CAN as in the case of the Multi RS?
If not, then no.
I think that is a ve direct only device for very simple installs. And is not mentioned in the datasheet as being possible.
ingo21 avatar image ingo21 commented ·
Thank you for your fast answer. and yes it just has a VE Direct port.
