Mark Reeves avatar image
Mark Reeves asked
Can the Emporia Vue Data be pulled into Venus OS GUI?
Has anyone successfully managed to pull data from an emporia vue and get it to display in Venus OS? I found some stuff on getting it into HA and using Grafana or Vuefana in this case but was not successful at getting them to work. This is what Emporia Community was able to offer me:
Community Forum Post: https://community.emporiaenergy.com/topic/api-to-pull-data/
Open Source Projects:
https://github.com/helgew/emporia-downloader
https://pypi.org/project/pyemvue/
https://github.com/magico13/ha-emporia-vue
https://github.com/jertel/vuegraf
Venus OSModbus TCPmodificationspower metergui mods
matt1309 avatar image
matt1309 answered ·
Hi @Mark Reeves
You might get some more responses moving this to the modifications section.
I'm not familiar with emporia, however if the data is obtained via a simple http api request then there are lots of similar custom drivers made by the community that you can probably tweak relatively easily.
The one that springs to mind is the shelly custom drivers made by the community. (I'll link a few below). Essentially they work the same as what you're looking for they query an api and get meter_data and then pass that into venus os dbus which is where venus os data is sent to. Except shelly devices are normally on lan.
Of course the data from the api request from emporia will be in a different format to shelly and you may also need to change the rate in which the emporia api is queried, (shelly devices are usually on lan and therefore having very frequent api requests wont be an issue but it might be if emporia has rate limiting on their api endpoints).
So in summary from the below shelly example you'll need to change url/endpoint details from local url to emporia endpoint.
You'll either have to edit structure of meter_data or edit the keys used to access data in meter_data when passing meter_data into the various dbus addresses
You may need to increase gobject.timeout_add to longer than 500ms. And also edit the signoflife objects.
Shelly victron custom drivers: dbus-shelly-3em-smartmeter/dbus-shelly-3em-smartmeter.py at main · fabian-lauer/dbus-shelly-3em-smartmeter · GitHub
Some info about using custom drivers in venus os just in case you're not familiar:
howto add a driver to Venus · victronenergy/venus Wiki · GitHub
I can't help with emporia specifics but if you share what the api request looks like im happy to lend a hand tweaking python drivers.
Mark Reeves avatar image Mark Reeves commented ·
matt1309 thank you for pointing me in a direction. I am new to Victron Community. I did move this question over to modifications. I am also looking for detailed explanation or instruction on how to adjust the dbus settings. Sadly I don't yet have a Victron Inverter. I plan to replace my chinese hybrid SG P6048 with a Victron at some point. until then everything is calculating a bit wonky. I am not sure if I can manually make the proper adjustments or not but will try to understand what is going on in the dbus. I started reading the gitub for it but it read like someone who already knew it in and out so it was hard to understand from a newbie standpoint. I will keep digging. Thanks Again!
matt1309 answered ·
Hi @Mark Reeves
It is a lot of information at once.
If your plan was to almost spoof a Victron inverter by getting data from emporia api, it's probably possible but might be a bit of a challenge.
Victron has most of it's code open which is great for implementing your own custom devices (drivers) as i imagine you've seen from that github page but doing this for a inverter is probably.
You would likely need to make a virtual inverter to get the support you're looking for. However you're right it would probably be quite clunky/a massive task to pull off. Definitely doable but would need a good amount of code and testing to get working flawlessly.
You'd probably need to populate multiple dbus services. The main one being com.victronenergy.vebus. Would be a lot of work and not sure the knock on effects of doing it.
I managed to get at the data from the rpi that is also my Venus OS. It was quite the chore. I pretty much bricked it one and started over from scratch this afternoon. This is what I am able to pull. I learned quite few neat tricks. "dbus-spy"
root@raspberrypi2:/data# python test.py
device_gid channel_num name usage unit
38677 1,2,3 Mains -0.020483587807549372 kwh
38677 2 in law 2 outlets 0.0 kwh
38677 3 In-Laws BR 0.0001572298208872477 kwh
38677 4 Georgia & Luke BR 0.0010538182481129965 kwh
38677 5 Master BR 0.000663721417321099 kwh
38677 6 Living Room 0.0009306949011484782 kwh
38677 7 Dryer 0.0 kwh
38677 8 AC Downstairs 0.0 kwh
38677 9 Range Oven 0.0 kwh
38677 10 Upstairs Furnace 0.0 kwh
38677 11 AC Upstairs 0.0 kwh
38677 12 Garage & Office 0.004305609236823188 kwh
38677 13 Fridge 0.0 kwh
38677 14 Christine's Office 0.0022326651806301536 kwh
38677 15 Washing Machine 0.0 kwh
38677 16 Downstairs Furnace 0.0 kwh
38677 TotalUsage TotalUsage 0.009343738804923167 kwh
38677 Balance Balance -0.02982732661247254 kwh
Mark Reeves answered ·
This is what most people with emporia are using to gain access to the data. I tried to run it on the Rpi but got a syntax error. Listed below is the raw code in the pyemvue.py file. I have a email and password but was not sure how to get those to negotiate to a token. I put the entire project folder in my /data folder on the rpi running Venus OS. I did change the permissions to 755 for almost all the files It seems to call out data from. I was fumbling my way throu with little understanding of how or what it was doing. The second part is getting the data useable by Venus OS. The API doesn't like to be polled more than once a minute which may not be super useful. I was hoping someone may have already had one and integrated it but it doesn't sound like it.
from typing import Any, Optional, Union
import requests
import datetime
import json
from dateutil.parser import parse
# Our files
from pyemvue.auth import Auth, SimulatedAuth
from pyemvue.enums import Scale, Unit
from pyemvue.customer import Customer
from pyemvue.device import ChargerDevice, VueDevice, OutletDevice, VueDeviceChannel, VueDeviceChannelUsage, VueUsageDevice, ChannelType, Vehicle, VehicleStatus
API_ROOT = 'https://api.emporiaenergy.com'
API_CHANNELS = 'devices/{deviceGid}/channels'
API_CHANNEL_TYPES = 'devices/channels/channeltypes'
API_CHARGER = 'devices/evcharger'
API_CHART_USAGE = 'AppAPI?apiMethod=getChartUsage&deviceGid={deviceGid}&channel={channel}&start={start}&end={end}&scale={scale}&energyUnit={unit}'
API_CUSTOMER = 'customers'
API_CUSTOMER_DEVICES = 'customers/devices'
API_DEVICES_USAGE = 'AppAPI?apiMethod=getDeviceListUsages&deviceGids={deviceGids}&instant={instant}&scale={scale}&energyUnit={unit}'
API_DEVICE_PROPERTIES = 'devices/{deviceGid}/locationProperties'
API_GET_STATUS = 'customers/devices/status'
API_OUTLET = 'devices/outlet'
API_VEHICLES = 'customers/vehicles'
API_VEHICLE_STATUS = 'vehicles/v2/settings?vehicleGid={vehicleGid}'
API_MAINTENANCE = 'https://s3.amazonaws.com/com.emporiaenergy.manual.ota/maintenance/maintenance.json'
class PyEmVue(object):
def __init__(self, connect_timeout: float = 6.03, read_timeout: float = 10.03):
self.username = None
self.token_storage_file = None
self.customer = None
self.connect_timeout = connect_timeout
self.read_timeout = read_timeout
def down_for_maintenance(self) -> Optional[str]:
"""Checks to see if the API is down for maintenance, returns the reported message if present."""
response = requests.get(API_MAINTENANCE)
if response.status_code == 404: return None
if response.text:
j = response.json()
if 'msg' in j:
return j['msg']
def get_devices(self) -> 'list[VueDevice]':
"""Get all devices under the current customer account."""
response = self.auth.request('get', API_CUSTOMER_DEVICES)
response.raise_for_status()
devices: list[VueDevice] = []
if response.text:
j = response.json()
if 'devices' in j:
for dev in j['devices']:
devices.append(VueDevice().from_json_dictionary(dev))
if 'devices' in dev:
for subdev in dev['devices']:
devices.append(VueDevice().from_json_dictionary(subdev))
return devices
def populate_device_properties(self, device: VueDevice) -> VueDevice:
"""Get details about a specific device"""
url = API_DEVICE_PROPERTIES.format(deviceGid=device.device_gid)
response = self.auth.request('get', url)
if response.text:
j = response.json()
device.populate_location_properties_from_json(j)
return device
def update_channel(self, channel: VueDeviceChannel) -> VueDeviceChannel:
"""Update the channel with the provided state."""
url = API_CHANNELS.format(deviceGid=channel.device_gid)
response = self.auth.request('put', url, json=channel.as_dictionary())
if response.text:
j = response.json()
channel.from_json_dictionary(j)
return channel
def get_customer_details(self) -> Optional[Customer]:
"""Get details for the current customer."""
response = self.auth.request('get', API_CUSTOMER)
if response.text:
j = response.json()
return Customer().from_json_dictionary(j)
return None
def get_device_list_usage(self, deviceGids: Union[str, 'list[str]'], instant: Optional[datetime.datetime], scale=Scale.SECOND.value, unit=Unit.KWH.value) -> 'dict[int, VueUsageDevice]':
"""Returns a nested dictionary of VueUsageDevice and VueDeviceChannelUsage with the total usage of the devices over the specified scale. Note that you may need to scale this to get a rate (1MIN in kw = 60*result)"""
if not instant: instant = datetime.datetime.now(datetime.timezone.utc)
gids = deviceGids
if isinstance(deviceGids, list):
gids = '+'.join(map(str, deviceGids))
url = API_DEVICES_USAGE.format(deviceGids=gids, instant=_format_time(instant), scale=scale, unit=unit)
devices: dict[int, VueUsageDevice] = {}
if response.text:
j = response.json()
if 'deviceListUsages' in j and 'devices' in j['deviceListUsages']:
timestamp = parse(j['deviceListUsages']['instant'])
for device in j['deviceListUsages']['devices']:
populated = VueUsageDevice(timestamp=timestamp).from_json_dictionary(device)
devices[populated.device_gid] = populated
return devices
def get_chart_usage(self, channel: Union[VueDeviceChannel, VueDeviceChannelUsage], start: Optional[datetime.datetime] = None, end: Optional[datetime.datetime] = None, scale=Scale.SECOND.value, unit=Unit.KWH.value) -> 'tuple[list[float], Optional[datetime.datetime]]':
"""Gets the usage over a given time period and the start of the measurement period. Note that you may need to scale this to get a rate (1MIN in kw = 60*result)"""
if channel.channel_num in ['MainsFromGrid', 'MainsToGrid']:
# These is not populated for the special Mains data as of right now
return [], start
if not start: start = datetime.datetime.now(datetime.timezone.utc)
if not end: end = datetime.datetime.now(datetime.timezone.utc)
url = API_CHART_USAGE.format(deviceGid=channel.device_gid, channel=channel.channel_num, start=_format_time(start), end=_format_time(end), scale=scale, unit=unit)
usage: list[float] = []
instant = start
if response.text:
j = response.json()
if 'firstUsageInstant' in j: instant = parse(j['firstUsageInstant'])
if 'usageList' in j: usage = j['usageList']
return usage, instant
def get_outlets(self) -> 'list[OutletDevice]':
""" Return a list of outlets linked to the account. Deprecated, use get_devices_status instead."""
response = self.auth.request('get', API_GET_STATUS)
outlets = []
if response.text:
j = response.json()
if j and 'outlets' in j and j['outlets']:
for raw_outlet in j['outlets']:
outlets.append(OutletDevice().from_json_dictionary(raw_outlet))
return outlets
def update_outlet(self, outlet: OutletDevice, on: Optional[bool]=None) -> OutletDevice:
""" Primarily to turn an outlet on or off. If the on parameter is not provided then uses the value in the outlet object.
If on parameter provided uses the provided value."""
if on is not None:
outlet.outlet_on = on
response = self.auth.request('put', API_OUTLET, json=outlet.as_dictionary())
outlet.from_json_dictionary(response.json())
return outlet
def get_chargers(self) -> 'list[ChargerDevice]':
""" Return a list of EVSEs/chargers linked to the account. Deprecated, use get_devices_status instead."""
chargers = []
if response.text:
j = response.json()
if j and 'evChargers' in j and j['evChargers']:
for raw_charger in j['evChargers']:
chargers.append(ChargerDevice().from_json_dictionary(raw_charger))
return chargers
def update_charger(self, charger: ChargerDevice, on: Optional[bool] = None, charge_rate: Optional[int] = None) -> ChargerDevice:
""" Primarily to enable/disable an evse/charger. The on and charge_rate parameters override the values in the object if provided"""
if on is not None:
charger.charger_on = on
if charge_rate:
charger.charging_rate = charge_rate
response = self.auth.request('put', API_CHARGER, json=charger.as_dictionary())
charger.from_json_dictionary(response.json())
return charger
def get_devices_status(self, device_list: Optional['list[VueDevice]'] = None) -> 'tuple[list[OutletDevice], list[ChargerDevice]]':
"""Gets the list of outlets and chargers. If device list is provided, updates the connected status on each device."""
chargers: list[ChargerDevice] = []
outlets: list[OutletDevice] = []
if response.text:
j = response.json()
if device_list and j and 'devicesConnected' in j and j['devicesConnected']:
for raw_device_data in j['devicesConnected']:
if raw_device_data and 'deviceGid' in raw_device_data and raw_device_data['deviceGid']:
for device in device_list:
if device.device_gid == raw_device_data['deviceGid']:
device.connected = raw_device_data['connected']
device.offline_since = raw_device_data['offlineSince']
break
return (outlets, chargers)
def get_channel_types(self) -> 'list[ChannelType]':
"""Gets the list of channel types"""
response = self.auth.request('get', API_CHANNEL_TYPES)
channel_types: list[ChannelType] = []
if response.text:
j = response.json()
if j:
for raw_channel_type in j:
channel_types.append(ChannelType().from_json_dictionary(raw_channel_type))
return channel_types
def get_vehicles(self) -> 'list[Vehicle]':
"""Get all vehicles under the current customer account."""
response = self.auth.request('get', API_VEHICLES)
vehicles: list[Vehicle] = []
if response.text:
j = response.json()
for veh in j:
vehicles.append(Vehicle().from_json_dictionary(veh))
return vehicles
def get_vehicle_status(self, vehicle_gid: str) -> Optional[VehicleStatus]:
"""Get details for the current vehicle."""
url = API_VEHICLE_STATUS.format(vehicleGid=vehicle_gid)
if response.text:
j = response.json()
return VehicleStatus().from_json_dictionary(j)
return None
def login(self, username: Optional[str]=None, password: Optional[str]=None, id_token: Optional[str]=None, access_token: Optional[str]=None, refresh_token: Optional[str]=None, token_storage_file: Optional[str]=None) -> bool:
""" Authenticates the current user using access tokens if provided or username/password if no tokens available.
Provide a path for storing the token data that can be used to reauthenticate without providing the password.
Tokens stored in the file are updated when they expire.
# try to pull data out of the token storage file if present
self.username = username.lower() if username else None
if token_storage_file: self.token_storage_file = token_storage_file
if not password and not id_token and token_storage_file:
with open(token_storage_file, 'r') as f:
data = json.load(f)
if 'id_token' in data: id_token = data['id_token']
if 'access_token' in data: access_token = data['access_token']
if 'refresh_token' in data: refresh_token = data['refresh_token']
if 'username' in data: self.username = data['username']
if 'password' in data: password = data['password']
self.auth = Auth(
host=API_ROOT,
username=self.username,
password=password,
connect_timeout=self.connect_timeout,
read_timeout=self.read_timeout,
tokens={
'access_token': access_token,
'id_token': id_token,
'refresh_token': refresh_token
token_updater=self._store_tokens
if self.auth.tokens:
self.username = self.auth.get_username()
self.customer = self.get_customer_details()
self._store_tokens(self.auth.tokens)
return self.customer is not None
def login_simulator(self, host: str, username: Optional[str]=None, password: Optional[str]=None) -> bool:
self.auth = SimulatedAuth(host=host, username=self.username, password=password)
def _store_tokens(self, tokens: 'dict[str, Any]'):
if not self.token_storage_file: return
if self.username:
tokens['username'] = self.username
with open(self.token_storage_file, 'w') as f:
json.dump(tokens, f, indent=2)
def _format_time(time: datetime.datetime) -> str:
'''Convert time to utc, then format'''
# check if aware
if time.tzinfo and time.tzinfo.utcoffset(time) is not None:
# aware, convert to utc
time = time.astimezone(datetime.timezone.utc)
else:
#unaware, assume it's already utc
time = time.replace(tzinfo=
time = time.replace(tzinfo=None) # make it unaware
return time.isoformat()+'Z'
matt1309 answered ·
Hi @Mark Reeves
How does the inverter data get into emporia.
You may have better luck capturing the data from the actual device. Rather than inverter sending to emporia then you getting from. Emporia. Why not try get it direct from inverter?
The emporia doesn't talk to the inverter it just monitors the flow of electrons via my L1 and L2 Mains as well as 16 separate circuits. It can see what my AC Loads are. My Solaredge does this as well. not the 16 individual circuits but it too looks at the L1 and L2 Mains via a ct. My Venus sees the data from my solaredge but is misinterpreting it. It thinks I have multiphase L1, L2, and L3 where in reality I have US 240V Split Phase. I cannot seem to fix this. I also have multiple instances of my Solaredge Inverter and I cannot figure out how to get rid of one. They display slightly different info. I am tempted to wipe out what I have and start over. I don't think there is a way to reset to factory default. I did get my battery connected via the smart shunt. I have an AC Coupled Hybrid inverter and I have been unable to get it to connect. I have added a canHAT to my rpi and wanted to try and get it to talk to this Chinese inverter but I don't have some key peices of info to make that happen. I plan to replace it with a Victron Multipass or Quatro but I am tapped on big purchases at the moment. This is what all 3 say when trying to look at them Side by side. I currently have my Hybrid Inverter turned off. I don't currently have solar connected to it. I have 2400 watts worth of panels but just haven't got them mounted yet. If I see a huge excess of solar I will turn it on but in charge mode. It pulls from the grid or my solaredge to charge the NiFe Batteries. Right now if I have an outage I can manually turn it on nd run t off the batteries. Since the sun has been so low for me this winter I have been just turning it off as the idle draw to just have it on is pretty high. It also does not do Freq shifting which I thought it would have to do in order to be able to AC Couple. This is not true. Hindsight is always 20/20. If I had it to do over I would have spent the $1700 I spent on it on something else. I bought it as I could not connect my 48V Batteries to my solaredge as it only supports HV Batteries. The three phase units like they sell in Europe handle 48V batteries. THey are not allowed to operate in the US or something like that. Been a mess and sadly have had 0 outages in the years I started planning for an outage. I have a 12Kw Propane Generator as well. I have 100 Gallons of Propane. well about 48 Gallons it says. I did get the Mopeka Pro Connected and may need some fine tuning but so far so good.
There are times when the data lines up pretty close and other times when it doesn't. I am not sure if I should have DC System turned on or not. I also realize I will need to do a battery SOC Calibrate in the near future. I have made progress but not sure how to clean up some of my learning curve.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
Experiments, Modifications and Adaptions. Mods (Modifications) can be made to Victron Software by the Community. Please use the modifications space for enthusiasts who want to push what is possible, without official Victron Support.
Modbus TCP Basics
