usmcrtr avatar image
usmcrtr asked
Supplemental Charger with MultiPlus-II 24 Volts DC, 2x120 AC wired in parallel
  • I have two Victron MultiPlus-II 24 Volts DC, 2x120 AC wired in parallel. Power assist is enabled. In this configuration the lowest AC input limit that can be set is a bit over 18 amps. What I would like to do is connect a Blue Smart IP22 24v-16 to the Lynx Distributor and power it with a small generator while the MultiPlus-IIs are inverting. The goal is to extend the time before needing to start the large generator. From what I have read there shouldn't be any issue doing this. Looking for anything I may have overlooked or suggestions.
Multiplus-IIbattery chargingcharge current limit
