pf-1 avatar image
pf-1 asked
removing usb stick on local systems
When removing an usb stick, a message appears that it should be "ejected" first.
1706687582541.pngThis makes sense.
But where is the place the USB stick can be ejected?
This location must not be in the VRM. It has to be local, i.e. on the user interface.
Especially for systems that are not connected to the Internet, updates must be made via USB stick. So especially for such systems I need a way to eject the stick .
firmware updatevrm firmware updatesd card
pf-1 avatar image
pf-1 answered ·
I found the solution myself.
The setting item I was looking for is not in the VRM portal (as I had mistakenly understood) but locally under the menu item Settings->VRM Online Portal
