I am in need of the 1959143.VFD file to roll back firmware on Multi + 48/5000/70-50
Hi @Frans
both 1959159.vff and 1959209.vff are available on Victron Professional
why do you need 143?
After upgrading to 195159 with batteries fully charged I get intermittent trip and restart even with relatively low load added. Indication on inverter "low bat + temperature" LED. The system worked perfectly with the 143 firmware. Also at times change over to shore power with high loads but also not as programmed.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
14 People are following this question.
