ajclarkies avatar image
ajclarkies asked
Smart Shunt ip65 ve cable
I have upgraded from the smart shunt to the smart shunt ip65. I have a BVM 700 battery monitor with a VE cable to the shunt, but the fitting that goes into the shunt is different. Is there an adaptor available?
SmartShunt
You had the normal shunt, not a SmartShunt?!
You can't connect the BMV to a SmartShunt, it's not designed for that. The SmartShunt is a stand-alone device.
