rowekfjo avatar image
rowekfjo asked
unidentifed led pattern on inverter
My old phoenix inverter 300w has an issue which isnt in the troubleshooting guides. I plugged a device in, which has charged perfectly before, but when i plugged it in this time the inverter shut down. Now when i try to start up the inverter i get a very quick green then red light then nothing.
the device i tried to charge works fine on mains power. I imagine i need a new inverter but now im worried about plugging the device in that caused the issue.
Phoenix Inverter
offroadflow avatar image offroadflow commented ·
Probably just a loose connection between the battery and the inverter.
Or the battery has died ....
rowekfjo avatar image rowekfjo offroadflow commented ·
Its all tight and the batteries are fine, they are running other pieces of equipment with no problems
