My pylontech up5000 is stopping charge at 93% temp at 30c CCL drops tobzero at 93soc
I installed latest firmware on cerbo but still the problem it there
Just a word of caution. Update all components if you update. Don't half and half it.
That is what the battery is reporting shown on the widget.
When it has. CCL of 0A it is telling the system not to charge.
The SOC thing not reaching 100% seems to be a pylontec thing. This is not the first post I have seen about it recently.
You do t show what voltage it has reached I assume the usual 52v? That is programmed in according to recommendations?
Further down the page.... FAQ.
The issue normally resolves over time.
So it seems that the battery gets a cell inbalance at around 91% the difference between highest and lowest gets to 0.2 volt but the charger/battery voltage is about 51.2 it then takes 2.5 hours of balancing then it goes to 52.47 and and 97% and charge normal till 100%
This is a new behavior it usually got stuck at 89 but was taking full charge and then after a while the soc jumped a bit and everything charged normal, but now it stop taking full charge and take long to balance
To get it past 91 I had to turn off dvcc from bms and put voltage to 52.8 and then it quickly balanced soc went up and I then returned bms control this took around 5min, but after battery discharge it gets stuck at 91 and takes the 2.5 hours to balance.
Should I maby change the charger settings from 51 to maby 52?
Could something happened in firmware as i was at 3.12 now 3.13
74 People are following this question.
What Lithium Battery Charger is compatible with Pylontech US2000 Plus Battery
Pylon tech battery sizing guide
Can you change the battery type in Multiplus II without MK3-USB Interface?
Is it possible to recover a pylontech battery from less than 44.5V (approx 40)
MultiPlus-II not going into float when Pylontech batteries are charged
