ddim0313 avatar image
ddim0313 asked
Lithium-ion battery settings via victronconnect app
Hi Guys,
I am quite new to this and I really need your help. I am running a 12v 200AH Lithium-ion battery with 150Amps BMS on SmartSolar MPPT 100/30 solar charge controller. I am trying to figure out which settings to use for this battery. Unfortunately, the only preset battery settings that I can see in the Victronconnect app related to Lithium batteries is for Lithium Iron Phosphate (LiFePo4) battery. This is not necessarily the best settings for a Lithium-ion battery, but I cannot make up which of the settings I REALLY need to change so this preset becomes suitable for Lithium-ion batteries - voltages from 14.4 to 14.6 and from 13.5 to 13.6, absorption time from 2 hours to 30 mins, etc. ? I have found many suggestion online, but I really cannot make up which ones to take and which ones to ignore. All suggestions will be deeply appreciated!
Many thanks in advance for your help!
MPPT SmartSolarLithium BatteryVictronConnect
regman54 avatar image
regman54 answered ·
If none of the pre-sets are suitable for your particular battery then make a custom charge profile using the battery manufacture's own specs. With Connect you can even play around with various setting using its built in Demo Library.
