With inverter turned off, nothing plugged into the downstream side, when I try to connect to the battery, I get a strong spark. Is there a fault?
This will most likely just be the inrush current from the battery as the unit's capacitors charge up (this is assuming that the unit is correctly connected, of course).
43 People are following this question.
