paulpe avatar image
paulpe asked
Configuring Easysolar 12/1600/70-16 230V MPPT 100/50 using Cerbo-S GX
Hi all
I'm putting a pick list together for a system, and want to know if it's possible to configure an Easysolar utilising a Cerbo-S GX, when connecting via VE-direct and/or RS485 cables? I'd like to avoid forking out for a MK3-USB interface (if I can) that I'll probably only use once in all likelihood!
Thanks
Paul
cerbo gxEasySolar All-in-OneVEConfigure 3
Paul B avatar image
Paul B answered ·
yes you can when the cerbo is connected to the victron vrm, via remote update and remote download and update.
multiplus must be connected via ve.bus which uses va rj45 cable between the multiplus and cerbo gx
paulpe avatar image paulpe commented ·
Brilliant, was hoping that would be the case - thanks!
