jctibor avatar image
jctibor asked
Victron inverter multiplus/quatro volatge range
Hello community,
I have a problem with available voltage range of 12V multiplus and Quattro. It is written in datasheet that minimum voltage is 9,5V and maximum is 17V but I am able to set 10,2 - 15V only. Don’t ask me for the reason - we use victron system for battery testing in our company.
Maybe there is an unofficial victron multiplus/quatro power driver or assistant which is able this range ? Or to unlock some let’s say expert mode to allow this non standard but still datasheet config?
in ve.config app is impossible to make it for me now.
Thank you ,
Best regards
VEConfigure 3voltagebattery system voltage
Paul B avatar image
Paul B answered ·
The stated range is the min and max that is allowed for that voltage ie 12 or 24 or 48 before the system will shutdown
jctibor avatar image jctibor commented ·
12 24 48 are nominal voltages. If you can see in datasheet for 12V is voltage min 9,5V and max 17V. But I am able to configure 10,2V and 15V , why ? I promise to my customer datasheet values :(
VEConfigure manual
VEConfig alternative method for VE.Bus using VictronConnect
