hansgeorgk avatar image
hansgeorgk asked
wifi0 and eth0 up at the same time
I need wifi0 and eth0 up and running at the same time both on different networks:
wifi0 should use route to router and connect to internet (192.168.1.0)
eth0 is for node-red data and connected to raspberry running influxDB and grafana (192.168.2.0)
I configured both in the console. I have explicitly not provided the Gateway in the eth0 config, since I do want node-red traffic to be connected to internet
I get the following result:
root@nanopi:~# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default * 255.255.255.255 UH 0 0 0 eth0
169.254.0.0 * 255.255.0.0 U 0 0 0 ll-eth0
172.24.24.0 * 255.255.255.0 U 0 0 0 ap0
192.168.1.0 * 255.255.255.0 U 100 0 0 wifi0
192.168.1.1 * 255.255.255.255 UH 99 0 0 wifi0
192.168.2.0 * 255.255.255.0 U 0 0 0 eth0
where wifi0 is missing the gateway to the router 192.168.1.1
If I manually add a gw like this:
root@nanopi:/etc/network# route add default gw 192.168.1.1
default 192.168.1.1 0.0.0.0 UG 0 0 0 wifi0
wifi0 is routed to router and the GX device is connected to internet.
But the only laste for a few second and the manually added route is gone :-(
After waiting for a few minutes the default route is loaded - sometimes ...
Or after a reboot the default route appears
hg@HGsMBP ~ % ssh -l root 192.168.1.2
Last login: Fri Jan 5 19:48:27 2024
root@nanopi:~# reboot
Broadcast message from root@nanopi (pts/0) (Fri Jan 5 20:03:07 2024):
The system is going down for reboot NOW!
root@nanopi:~# client_loop: send disconnect: Broken pipe
Last login: Fri Jan 5 20:03:51 2024
any idea to get the network configured correct and to have it working in a reliable mode?
thanks
HG
TCP IP Networking
