sailordavid1969 avatar image
sailordavid1969 asked
Cerbo GX to Solar MMPT, Smart Shunt, and 2 Phoenix 50 amp SmartChargers
Hi, I have 4 Solar MMPT controllers, 1 Bluetooth Smart Shunt, 2 Phoenix 50 AMP Chargers and just pruchased a Cerbo GX-S for my Boat. I am trying to figure how to best connect all these devices together. I was planning the following:
- Daisy Chain with Ethernet cables the Solar MMPT into the VE Can port terminating in the Cerbo VE Can port
- VE Direct Cable from Smart Shunt to Cerbo GX-S
- VE Direct cable from each Phoenix Charger to Gerbo GX-S
I would then use up all 3 VE direct ports and the Can Bus port on the Cerbo.
Does this seem correct?
It looks like another potion for the MMPT is USB from each unit to a Hub and then run the Hub to the Cerbo GX-S but that seems like more cables and points of failure.
Thanks
Dave
cerbo gxSmartShuntpheonixmmpt
JohnC avatar image
JohnC answered ·
Hi @sailordavid1969
Sounds ok. I'm surprised though that all your mppts have CAN ports, as that's usually applicable to the larger units, as it's a more expensive protocol to manufacture. Don't forget the CAN terminator plugs.
If you actually need (now or future) a usb hub, use a quality, externally powered hub.
