samaya avatar image
samaya asked
Inverter/Chargers combine question
If I combine two Inverter/Chargers, lets say Victron Multiplus - one on 220v 1600W and the other on 110v 1600w can I rely on 3200W power supply?
multiple inverters
klim8skeptic avatar image
klim8skeptic answered ·
@Samaya You can not combine the output from a 120vand 230v inverter.
Very bad things will happen should you try this.
Kevin Windrem avatar image
Kevin Windrem answered ·
Even if you match the output voltages with a transformer
Very bad things will still happen.
Victron inverters can be paralleled only with specific programming and interconnected VE.Bus as well as specific interconnection cabling (both AC and DC). There's a manual for this.
But mixing a Victron with another inverter or even two Victrons that are not set up for parallel operation will be very bad.
