andrewapel avatar image
andrewapel asked
Connecting two different victron inverters
Can I connect to different victron inverters by using the ax output of one eg multiplus II as the ac input of the other eg multiplus both 24/3000 so when more power is needed the second inverter kicks in this is because I already have a multiplus and want to buy a second inverter
multiple inverters
Justin Cook avatar image
Justin Cook answered ·
While connecting the output of one inverter to the input of another inverter is not supported and never really a good idea since it tends to cause multiple cascading issues either immediately or over time, most MultiPlus units are parallel-able; review the manual for installation and all associated wiring and technical consideration documents linked therein.
rvicev avatar image
rvicev answered ·
Please stop posting this - this video is incorrect (as noted in the "for testing and demonstration purposes only"), unsupported, and will not function reliably, besides possibly causing damage to both inverters involved and posing a potential risk to life and property.
