deunan avatar image
deunan asked
Multiplus 2 in charging mode, ac-in fluctuation
i have set my MP2 to limit ac-in to 15A, charger enabled to 5A and made a couple of assistants to ignore ac-in but when aux1 is closed ac-in is not anymore ignored and when aux2 is closed charger is set to 60A.
So i expected this behaviour: when aux 1 is closed, all the loads are supported by the MP2 with ac-in and the battery gets charged around 200/250W, if aux2 is closed to, the battery gets charged around 3000W. But that not happens.
When aux1 is closed, ac-in kicks in, cover the loads but the battery gets charged max 70W. When aux2 is closed the ac-in power fluctuate a lot in cicles. it cover the loads, ramps up to max, stay there a second or two, then lower down to cover the load and the cycle repeats. It's not just some wrong readings. The BMS reports the same behaviour, it's a jk-bms connected via CAN
I have no idea why it's making a such thing or if it's a normal behaviour. All is updated at the newest firmware.
Can someone point me in the right direction to debug this?
Thanks.
MultiPlus Quattro Inverter ChargerLithium BatteryRelayac ignore
Michelle Konzack avatar image
Michelle Konzack answered ·
The devil is here
becsuse the 15A is AC, but the 5A is DC.
I assume you have the MultiPlus-II 12/3000 right?
70 Watt divided by 5A is 14V,... Oop!
Simply set the charging current to the maximum and have fun!
deunan avatar image deunan commented ·
Nope, it's the 48/5000
