Hi , I am getting a temp warning from the victron multiplus, my question is , does it give this warning if the batteries overheat or only internal temperature of the multiplus , checked the battery temp they are at 48 degrees c
The temperature light on the Multiplus refers to the Multiplus internal/electronics temperature - NOT the battery temperature.
Refer to extracts from the manual;
8 People are following this question.
