How do you proceed to know if a battery is good or bad?
Thanks
Thanks
The only thing to be sure is, to do a manual capacity test. The discharge rate depends on battery type. It is basically like, putting a defined load on a fully charged battery and measure the time until it reaches low voltage. A BMV can be very helpful to make this tests. Refer to the batteries datasheets, for discharge rates and voltages.
Regards,
Markus
Thank you, do you know how to program the BMV relay in order to cut of the phoenix inverter from feeding load whed SOC reach 50%?
Yes, it should work, just in connecting the BMV relay output with the remote switch input of the Phoenix. You can program the relay in Victron Connect App, for opening at 50% SOC.
Regards,
Markus
5 People are following this question.
