bradr avatar image
bradr asked
Can Multiplus be programmed with iOS?
Hello Victron World.
I have a new Multiplus 12/2000/80 and both my MacBooks operate on macOS 10.15. Everything I’ve read indicates that you must have macOS 10.2 to run the Victron Connect software for programming the Multiplus. I cannot upgrade the macOS on either of my MacBooks. Which prompts a couple of questions:
1). Can the iOS (iPad, iPhone) version of Victron Connect program the Multiplus yet?
2). If I have to breakdown and purchase a new MacBook (UGH!) does the MAC OS version of Victron Connect operate on macOS 14?
Additionally, does the #2 dip switch still have to be in the “ON” position for programming the Multiplus via the MK3-USB interface?
Thanks all.
VictronConnect
Kevin Windrem avatar image
Kevin Windrem answered ·
Victron provides download links to older versions of VictronConnect that should run on your MacBook. Refer to section 4.6 in this document:
https://www.victronenergy.com/upload/documents/VictronConnect_Manual/8778-VictronConnect_manual-pdf-en.pdf?_ga=2.214501591.1583957945.1701917974-1268521401.1700274066
You can not use your iOS devices. The MK3 USB adapter needed to program the Multi directly won't work on iOS devices.
bradr avatar image
bradr answered ·
Thanks Kevin.
vward avatar image
vward answered ·
If you need VE configure, you can run windows on a macbook with Parallels, an emulator. This allows you to upload and download files to VE configure from you network, without connecting directly.
bradr avatar image
bradr answered ·
Thanks @VWard . Parallels is an option I’ll consider.
lee-taylor avatar image lee-taylor commented ·
I am not a fan of emulation as its an extra layer between the usb and the cpu. I have a 2013 macbook pro which I have enabled bootcamp on and downloaded a copy of windows 10. I haven't bothered registering it so it limits the functionality but it will run VE Connect. You do need a fair bit of free disk space though.
vward avatar image vward lee-taylor commented ·
But you don't need to use the USB, you can use your network
nickdb avatar image
nickdb answered ·
If you can create a config on a windows device, the mac/IOS device can use remote configure via the VRM portal to upload the file.
The trick is just having access to a windows system.
I remote desktop to a cloud-based windows system I have to use veconfigure, and then push it via my other devices.
Victron connect works quite well for parameter changes, it's just useless for assistants.
