Hi, can the EasyPlus 12/1600/70 inverter/charger be used with non-Victron LiPoFe4 batteries?
I'm planing to use the Winston LiPoFe4 cells with the REC-BMS.
Thanks a lot in advance!
@AlexR sure, why not.
Just make sure the multi is programmed for your battery voltages.
And your BMS is effective in protecting your cells.
Perfect, thanks :-)
Does it mean, that the EasyPlus is in its configuration possibilities identical with the MultiPlus? I see in the MultiPlus docs the additional info: "Lithium Ion battery compatible"
@AlexR the Easysolar is essentially a multiplus with the addition of a small ac switchboard.
Have a look at the Victron Connect / VE Bus manual for config details.
57 People are following this question.
