Can someone either explain or point me in the right direction where I can find information about the Lynx Relay, specifically the "Remote" and "Charger mode" options?
The manual doesn't reference them.
I believe I figured out what those options are for. I had to look at the settings through the cerbo remote console in order to figure them out.
Remote is for “manual control” and charger mode is for “generator start/stop”. It just seems like the terminology is a little bit different in VictronConnect vs the remote console.
Lynx Shunt VE Can online manual
48 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
