I have to install a Lynx Shunt VE.Can and a Lynx Distributor. Both have 2 RJ11(or 12) sockets. And a short wire is supply with same connector. I don't find any manual or any schematic about those 2 device.
Can someone help me, please ?
Hi Couleur_solaire.
When I built my DC Lynx system,I asked Johannes from Victron the same question!.
The rj11 fly leads are to connect the VE-can to the distrubutor for feedback on when a fuse blows.when the fuse way blows the LED changes colour from green to red for visual indication and sends the info back to the ccgx over the VE-can.however this is a future upgrade and is not yet implemented,so I was advised.
While I agree these products could use some more documentation, there is some.
Have you read these:
https://www.victronenergy.com/support-and-downloads/manuals#item=manuals-lynx-ion-shunt-350-600
Many thanks, Guy for your answer ! The right solution is in the 3rd links, because the 2 first are about Lynx Ion, so for LFP batteries…
An other disagreement, is that the type of fuse (CNN fuse) in the lynx shunt is not the same that all of other devices (Mega fuses) and not very easy to find ! One is on Victron pricelist, but 325 A is often not enough in a DC distribution. For example in a 3 phases system…
In most of all systems I've made, I installed ESP DC Link Boxes, easy and fast to connect and looks very well ! But today I have to make a 3 phases system with 4 series of batteries. So my plan was to try the Lynx way for DC distribution… It's not a so funny experience !
(sorry for my so bad english !! ;-)
Why Victron cant include that CNN fuse for the shunt as NOBODY carries this stock and when you finnaly get the shunt you find that it cant be used without this fuse . I spent much more in my time WASTED than the price of fuse especially as all the other shunts work out of the box
Thanks but Im using 200ah agm and can't buy another victron shunt model because the lynx shunt I bought does not have fuse.
Furthermore the shunt is not even working and I've had to bypass it but that is another story . Also Ive had to get a RMA for the Mppt that suddenly stopped working
and now after weeks of troubleshooting it looks like the ground relay may also be faulty with the Multiplus 48v 230v 5000 and will also need a RMA . The problems appears intermittently .
bottom line after all this money and time I'm not satisfied with Victron right now and the illusive Shunt Fuse above just adds to the irritation.
5 People are following this question.
