If I connect the Solid Switch H pin directly to 12V what is the current that will be drawn?
(I will be controlling it with an Optocoupler that can take up to 15mA, so need to know if I'll need to put a resistor inline...)
The datasheet lists the minimum switch.on current as 30 microA. It also states that over 1 month it will consume 0.04Ah, which calculates out as about 55 microA.
I did see the 0.04 Ah/Month, but I would assume that is the power between BAT+ and BAT- and is not the current flowing into the Remote pin (which is less I would assume)
39 People are following this question.
