Lionel SEYDOUX avatar image
Lionel SEYDOUX asked
force equalization?
Hi folks!
In the southern french Alps (not at sea!) my 30kWh batteries are fed with a MPPT 150/65, managed with a BMV 712 and used by a multiplus24/5000/230 all installed 2 week ago.
How do I force an equalization after topping the electrolite with distilled water?
thanks
Lionel
battery charging
Mark avatar image
Mark answered ·
With the MPPT use the VictronConnect app, either via Bluetooth interface or a VE.Direct to USB cable - there is a button to manually trigger it.
If you want to use the Multiplus and dont have a Venus device, there is a complex switching operation to trigger it - refer to the online manual;
https://www.victronenergy.com/upload/documents/Manual-MultiPlus-5k-100A-230V-(firmware-xxxx4xx)-EN-NL-FR-DE-ES-SE.pdf
With whatever option you choose to use please take care to ensure that all the equalization settings are appropriate/correct for your battery type BEFORE activating the equalization phase - as it is easy to destroy a battery bank if excessive voltage/current/time is used.
