Olivier Wouters avatar image
Olivier Wouters asked
Can I lower the DC input low restart value (restart issue) ?
Hi, I have an off grid system with a multiplus II 48/3000/35-32, a BSL Batt 100Ah 5.1kw and a MPPT. Not much sun for a week now (Ireland) and I don't have a generator. I'm losing 2% of SOC every day which seems fine to me until my inverter decided not to start because of a low battery alarm. I switch the inverter on and off everyday to save energy, I only produce 120W a day (4 panels and trees around). Indeed I configured the DC low restart to 52V and I'm just under 52V (I briefly went over and the multiplus started so everything works), the battery is at 58% SOC. My question is can I lower the value of DC input low restart to 51V (BSL Batt Victron config manuals are quite confusing, I have the value of 51V and 52.5V but the config is ESS oriented ...) ? Will it damage the battery to stay too long too low (by the way what is too long too low :) ) ?
Have a nice day,
Olivier
Multiplus-IIoffgridlow battery warningbslbatt
kevgermany avatar image
kevgermany answered ·
Yes you can lower it.
If they're LiFePO4 batteries, no risk. If AGM, you're going to shorten battery life by leaving them in a low state of charge.
Might help if you turn on AES, even though you are turning the inverter off. Search mode is the most economical.
Olivier Wouters avatar image Olivier Wouters commented ·
Thank you very much Kev. For the AES, all my power draws are very low : LED lights (5W each but connected in pair), the gas water heater (always on, use electricity for control), the spark for the gas burner. Would AES suit this scenario of very low needs ? Maybe if I want electricity I just turn on the lights and the inverter would kick in (which would fit my needs at the moment) :). I could try with a threshold of 8W, something higher than what the gas water heater needs but lower than 2 LED lights.
kevgermany avatar image kevgermany ♦♦ Olivier Wouters commented ·
It needs a draw of about 40W to switch AC on. At least that's what I found a while ago. It was supposed to revert to the original value of about 10W, but not sure if this has happened yet. Can't experiment at the moment.
Victron & BSLBATT Lithium batteries
MultiPlus-II Product page
MultiPlus-II Manual
Multiplus-II GX Online Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
Victron Offgrid page
