Hi guys.
I got Victron SmartSolar 100/20, SmartShunt 500A/50mv, and a Smart Battery Sense, will it also work with a 36V LiFePo4 battery? All of them?
Thanks.
Hi guys.
Thanks.
Take a look into the datasheets and the VictronConnect demo library.
All that devices can handle 36V.
It just sometimes doesn't auto detect the 36v voltage . Make sure the battery voltage is set correctly when you make your settings.
No, if you look at the specs it says 38-66v, so 36 is outside the specs.
The SmartShunt and Smart Battery Sense have a voltage range of 6,5-70V and 8-60V.
43 People are following this question.
